bicci
Jan 30, 2008 3:29 AM UTC
cortex flash erasing
Posted on January 30, 2008 at 04:29
    sjo
    May 17, 2011 10:22 AM UTC
    Posted on May 17, 2011 at 12:22
    works fine with crossworks and jlink, check you have the latest versions of both installed.
    Cheers
    Spen
    bicci
    bicciAuthor
    I'm using Crossworks with segger j-link. I have a problem to erase flash where the downloader writes the application code. I try to erase it also manually (with 'erase all' command) but it is not erased.
    Is there any one that know a solution ???
    Thanks.
