converting stlink to jlink in linux
  • August 13, 2023
  • 4 replies
  • 3300 views
Hello , is there a way I can convert an stlink to jlink  in linux (ubuntu 22.04). STSW-LINK009 is only available for windows
Pavel A.
August 13, 2023
1. Try to run it under Wine.  2. Install Windows in a virtual machine.
AScha.3
You don't need any driver on Linux... st-link is working always, If working st-link is connected.
No need for j-link.
sgnAuthor
I'm trying to debug  zephyr (rtos) code from vs-code and seems  stlink ,stutil  server executable  could not be found I tried to  install stlink-tools still didn't  work , so I opted for installing jlink which whose executable was found , so I'm trying to convert the stllink to jlink to enable debugging ,
AScha.3
on some boards you can convert st-link to j-link, but need windows system to do this (afaik)
https://www.segger.com/products/debug-probes/j-link/models/other-j-links/st-link-on-board/
otherwise you have to buy a j-link.
