Mohan1
Oct 22, 2019 12:42 PM UTC
Conversion of decimal to string
Hello, I am getting data in decimal format and to need to convert it into string.So how can i do it?
    Tesla DeLoreanBest answer
    Oct 22, 2019 2:09 PM UTC
    The math/logic here are pretty simple, sort of thing given as a homework assignment to check if you have some grasp of topic.
    Tip:do it backward, generating the least significant digits first.
    Library also has things like itoa() which is more lightweight than sprintf() and variants.
    http://www.cplusplus.com/reference/cstdlib/itoa/
    Ozone
    Principal
    Oct 22, 2019 2:02 PM UTC
    sprintf() would be the simplest way.
    Mohan1
    Mohan1Author
    Nov 1, 2019 5:12 AM UTC
    Thank you so much sir.I used itoa function and it shows correct decimal value in docklight that i required.Thank you once again sir.
