Senior
Mar 25, 2020 7:41 PM UTC
Controller reset every 500 ms periodically
I am working on stm32f429 and micro controller reset every 500 ms, iwdg is not active but, it seems, it is activated by hardware or something which force cpu reset.
How can i get rid of this?
Please help,
BR,
MHaji.1Best answer
Senior
Apr 5, 2020 12:07 PM UTC
Apparently hardware watchdog in all M4 controllers are activated by default in optional byte ...
Thanks for replying... problem is solved.
Mar 25, 2020 7:51 PM UTC
Diagnose the underlying problem?
Scope the NRST pin, the VCAP and VDDA supply pins.
Check for external sources connected or sharing the NRST
Does the problem occur with a simple LED Blinky program?
Is this something that started occurring recently, with specific new code or function?
ST-LINK? DISCO/NUCLEO board? Your own?
Mar 25, 2020 10:14 PM UTC
Why do you think this? Did you look at IWDG registers? If so, they don't set themselves. Something in your code is, so find it.
MHaji.1AuthorBest answer
Senior
