There still seems precious little information about this! :( There is a datasheet, but I can't see anything else - User Manual, FWLib support, IP Stack support, etc, etc... Will the Ethernet function be compatible with (or even the same as) that used in the STR9? In other words, will it be possible to take the existing InterNiche demo for the STR9 and port it with minimal changes to an STM32F107...?
