Aqsa
May 19, 2023 10:48 UTC
connection of SWD pin of ST-LinkV3set with STM32F767zi error in debugging .
I am using STM32F767zi. I modified this board by removal of the 0 ohm resistor required to test MCU power. I connected this stlinkv3set SWD pin to this board SWD, but while debugging a programme, it displays the error "Error in MI command final launch failed." Can somebody assist me in resolving this problem?
May 19, 2023 11:59 UTC
Check with STM32 Cube Programmer. Confirm connectivity.
An unpowered MCU will not be responsive to connection attempts.
Aqsa
AqsaAuthor
Jun 13, 2023 12:12 UTC
If it's connected on the cube programmer, does it mean it's not burned? But it is not displaying the value on the screen. How can this be resolved?
Jun 13, 2023 12:33 UTC
Burned? What value(s)?
If you can connect to the STM32 and read/write memory content, then at least that portion is viable.
Now focus on settings and usage by CubeIDE and GDB which are causing problems there. See other posts on same error..
