Connecting a debugger probe to a chip in standby mode: L0 vs F103
I was testing f103 in a standby mode and wiring a nRESET line was enough to connect to the chip with a Segger debug probe in a connect under reset mode. But apparently L0 chips also require pulling BOOT0 pin high. I am guessing that is because Flash is turned off? But I can connect to f103 in standby mode with BOOT0 low just fine. Does it mean I somehow didn't switch it to the full power down mode or standby on f103 doesn't turn FLASH off?
