Mar 16, 2024 11:08 AM UTC
Connect battery to BL475E-IOT01A Discovery Kit
I want to supply my St Iot discovery kit board with a battery supply, I have changed the header pin to 5V_VBAT. As i am connecting my battery to the Vin and gnd pins the red LED keeps blinking and LD5 is off.
Kindly give some suggestions how should I fix this.
I am using a 5v rechargeable battery for this, can I use a 9v battery for the same or it will damage the board ?
STTwo-32
Mar 16, 2024 12:15 PM UTC
Hello @Arhum_29
I suggest you to take a look at the part 7.4 of the UM2153 where you can find more details about how to supplie your board.
Best Regards.
STTwo-32
