peterdonchev
Senior
Confused on TIM_SelectCCDMA
Posted on July 14, 2017 at 15:19
I want to use Timer Capture event to generate DMA requests, how TIM_SelectCCDMA should be called?
TIM_SelectCCDMA(TIMx, ENABLE)?
This will set CCDS bit, but according the reference manual for STM32F303, bit CCDS should be 0.
    waclawek.jan
    Posted on July 17, 2017 at 12:50
    You want to set one of the CCnDE bits in TIMx_DIER (TIMx DMA/Interrupt enable register) register. I don't know how is this called in Cube.
