clock cycles needed for eeprom write
Hello ,
i am looking to know for STM32L051 how long will it take a byte to be written in to eeprom.
while writing eeprom does it have any limitations like UART intteruptions?
Tesla DeLoreanBest answer
October 23, 2023
Use a TIM counting off micro-seconds to measure the time across the functions. Or toggle a GPIO and scope it
If it's the same as the STM32L1 family (which it probably is), it will not stall the bus unless you read/write to the same bank before the first operation is done.
Datasheet says programming time is 3.94 ms max.
Piranha
Principal III
October 14, 2023
Ironically that time is about 10 to 100 times worse than for a software EEPROM emulation or a proper storage system in FLASH memory.
The below is the function i use ,
 flash_unlock( );
memcpy( &data_w, data_ptr, sizeof( data_w ) );
status = HAL_FLASHEx_DATAEEPROM_Program( TYPEPROGRAMDATA_WORD, Address_Src, INVERTED_DATA( data_w ) );
flash_lock( );
