Changing I2C Address for Accelerometer Sensor and Initialization Query
I have a BMA5 accelerometer sensor and I want to change its I2C address. I have enabled I2C1 in cubemx and set pull-up for SDA and SCK lines. I need guidance on the program algorithm and cubemx setting for this task as I am new to this field. Also, I would like to know, do I have to initialize the I2C1_init() again after setting the new address. Thank you.
Jacob WOODRUFFBest answer
Hi Azad,
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Regards,
Jake
ST Support
Hi Azad,
Regards,
Jake
ST Support
Karl Yamashita
Principal
July 3, 2024
There isn't a search result for a BMA5. You have a link to a datasheet?
