PMath.4
Senior III
July 4, 2020
Changing default parameters of main()
I've got an application where the main() function needs to be non-standard. In older version of GCC this wasn't an issue but the newer versions seem to have changed something
I need:
void main(long long int *c, long long int *b)
but GCC is overriding this. Is there a compiler switch to let me do what has worked fine previously?
    How are you passing parameters to main() in an STM32 application?
    There are only two allowed forms for arguments of main() per the C standard:
    int main (void);
    int main (int argc, char* argv[]);
    berendi
    Principal
    July 5, 2020
    What do you mean by that? Does gcc rewrite the code or what?
