ETone
change dac dma from circular to normal using HAL?
  • March 4, 2023
  • 4 replies
  • 1077 views
AScha.3
no. why ?
ETone
EToneAuthor
Because in some sections of my application I want the dac to output continuous waveforms from a lookup table and in other sections I want it to output a single pass of a lookup table in response to an event. What I now have found to work is:
((DMA_Stream_TypeDef  *)hdma_dacX_chx.Instance)->CR |= 0x100;
For continuous output, bit 8 set selects continuous and
((DMA_Stream_TypeDef  *)hdma_dacX_chx.Instance)->CR |= ~0x100;
For one shot output, bit 8 reset selects normal, X is the dac and x is the channel.
The reference manual indicates the bit 8 information but getting to it using HAL definitions required some investigation.
waclawek.jan
No. &=.
ETone
EToneAuthor
Yes, my bad.
