Hmizr.1
Cannot write to external flash or erase external flash if memory map was activated before
  • August 27, 2020
  • 0 replies
  • 434 views
hi,
i want to flashing to flash but i have a problem
If the flash is not entering memory map at all , the flashing is working
if memory map was activated, even once, the flashing is failing
