TShet.2
Can we build a DALI slave board using SMT32F030CCT6TR controller while receiving DALI data through GPIO input.
  • March 29, 2023
  • 1004 views
I need to build a DALI slave board which receives DALI command, now I am receiving the dali data through GPIO input pin.
Can I capture entire dali packet using timer to by checking the GPIO input status.
gbm
Use timer input capture function - this will give you precise timing of DALi input signal.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
TShet.2
TShet.2Author
I am currently using Pin A5 as GPIO input and reading the pin state every 100micro second, as the DALI data rate sends a bit every 833 micro second.
Do you think this method will work?
