MSipo
Senior II
November 23, 2022
Can the timer be used to divide incomming pulses and send the result out?
Is it possible to configure 1 or more timers to divide incomming pulses on a pin by a factor (for example 8) and send out the result on another pin?
Like this:
0693W00000WJKegQAH.pngThat way I would not need to implement the counter in software.
    Peter BENSCH
    Peter BENSCHBest answer
    This should be possible with the timers, e.g. with the function Output Compare Toggle. Details can be found in AN4013 or in the respective reference manual, section Output compare mode.
    /Peter
    Peter BENSCH
    /Peter
