MMars.1
Can the SPI run at another voltage apart from VDD?
The data sheet isn't specific, apart from one diagram Figure 13 that shows IO's box with an arrow from VDD that then connects to a level shifter to the core domain.
Please advise. A real handy feature would be to alternative voltage IO for the SPI's.
waclawek.jan
Which STM32?
GPIO levels apply to all IO, except where explicitly noted otherwise.
Some STM32 have a group of IO supplied from a separate VDDIO2 pin.
MMars.1
MMars.1Author
Thank you.
I wrote in in the original question but they cropped it to STM32 MCU's..
Its the STM32H755xI.
waclawek.jan
Who cropped it and where's the original question?
According to 'H755 DS, there's no VDDIO2 but there appears to be a group of pins supplied by VDD33USB, _u suffixed in STM32H755xI pin/ball definition table, which maybe can be used at different voltage if USB is not used.
