Can't create dynamic frequency Signal
I am trying to create a signal that changes its frequency in dynamic way using timers
but i am having some issues to do it
can anyone give me some tips for easy implementation to do this task
Gyessine
GyessineBest answer
Hello @IsmailYangui
Can you provide more details about your problem, such as the product you are using, the type of timer you want to use (advanced, general-purpose, etc.), and the specific issue you are experiencing?
If you have already attempted this in a project, can you share your .ioc file with us?
However, I have attached a project that uses the NUCLEO-U083RC board to generate a timer signal with a changing frequency during runtime. The signal starts with a 100 ms toggle for one second, then toggles every one second. You can visualize the signal using a logic analyzer, an oscilloscope, or the user LED.Capture d'écran 2026-02-27 153116.png
I hope this helps for now.
We look forward to your feedback.
Gyessine
Please expand on this. You haven't specified enough detail.
Andrew Neil
So what, exactly, have you tried?
And what "issues", exactly, are you having?
You haven't even said what you're using!
How to write your question to maximize your chances to find a solution
I'm using stm32h7A3
my problem that i dont have any generated signal despite code compiling correctly
Andrew Neil
Note that everyone can see all posts - there's no need to repeat the same thing multiple times for multiple people.
You can use '@' to mention multiple people in one post.
Gyessine
GyessineBest answer
Hello @IsmailYangui
Gyessine
I'm using stm32h7A3
im gonna review your project and come back with feedback as soon as possible
i'm using stm32h7A3
Code compiling is a very low bar. It does not mean the code works or is functional in any capacity.
