BTrem.1
Senior
August 18, 2020
Can STM32F303 be programmed in multi-drop?
  • August 18, 2020
  • 3 replies
  • 667 views
We have a system that uses hundreds of modules. Each module has 4 STM32F303 MCU's. Within a single module we would like to have one programming interface. Is there a means to program 4 MCUs with one programming interface?
Uwe Bonnes
Chief
August 18, 2020
You can daisy-chain the JTAG interface
BTrem.1
BTrem.1Author
Senior
August 21, 2020
Is the jtag interface the only one that can be used for debugging & programming 2 or more MCU's on a board? Are there any App Notes that discuss this?
August 21, 2020
If you have your own boot loader you can implement alternate approaches to programming.
Parts could share a common UART RX, and then diode-and UART TX provided you only have one talk at a time. Each device could be addressable if it could identify it's position on the card/module
