Manoj Hiwarkar
Aug 20, 2018 10:30 UTC
CAN messege transmission using HAL LIBRARY
Please tell me how to send a CAN message using HAL_CAN_Transmit function.
For ex. if I want send a hex number say 0xFE.
    T J
    Senior III
    Aug 20, 2018 12:15 UTC
    i use the cube to initialise all the peripherals with HAL. including CanBus
    but it ends there,
    I use this to transmit.
    if ((CAN->TSR & CAN_TSR_TME0) == CAN_TSR_TME0) // (1) fifo0 is empty
     CAN->sTxMailBox[0].TDTR = 8; // (2) length
     CAN->sTxMailBox[0].TDLR = 0x11223344; // (3) 4bytes
     CAN->sTxMailBox[0].TDHR = 0x44556677; // (3) 4bytes
     CAN->sTxMailBox[0].TIR = ((uint32_t)TxMsgID << 21 | CAN_TI0R_TXRQ); // (4)
    // sent to fifo now, if the line is idle it will start now
     if ((CAN->TSR & CAN_TSR_TME1) == CAN_TSR_TME1) // (1) fifo1 is empty
     if ((CAN->TSR & CAN_TSR_TME2) == CAN_TSR_TME2) // (1) fifo2 is empty
    Aug 20, 2018 12:42 UTC
    Perhaps looks at some code examples for the STM32 part you're using?
    STM32Cube_FW_L4_V1.12.0\Projects\STM32L476G-EVAL\Examples\CAN\CAN_Networking\Src\main.c
           /* Set the data to be transmitted */
           TxData[0] = 0xFE;
           /* Start the Transmission process */
           if (HAL_CAN_AddTxMessage(&CanHandle, &TxHeader, TxData, &TxMailbox) != HAL_OK)
             /* Transmission request Error */
             Error_Handler();
