October 3, 2023
You could use a PI Pico W for USB-To-CMOS Serial and for a WiFi connection
https://www.raspberrypi.com/news/raspberry-pi-pico-w-your-6-iot-platform/
pttAuthor
thanks for the response.
another question: if i have about 50 devices like this one for qr codes, how can i use only one com port in the pc and communicate with the 50 devices? is there any way to avoid to have 50 com ports on the pc? thanks again in advance
pttAuthor
what about to use this device connected directly to the qr module? can i use the wifi as input and send to the qr module with ttl?
https://es.aliexpress.com/item/4000571293224.html?spm=a2g0o.cart.0.0.f8e07a9dqKzpYm&mp=1&gatewayAdapt=glo2esp
October 3, 2023
Possibly, but just as a serial port, you'll need to review how you might communicate with one or many. Perhaps by a broadcast UDP.
I think the SW development with the Arduino IDE might still be easier via the RPi Nano W. Powering the display via USB Charger into RPi. For the 50-up perhaps via specific addressing, or broadcast UDP socket connections from PC.
pttAuthor
If i can use the Wifi module connected to the qr module, the communication is not a problem once the wifi module has an IP address.
