re.wolff9
Senior
Apr 11, 2018 12:03 PM UTC
Can I leave VBAT unconnected?
Posted on April 11, 2018 at 14:03
I Have a project that can be populated with or without RTC and a battery. Can I leave the VBAT pin unconnected when building PCBs without the battery?
I'm using an STM32F072.
#stm32f0 #stm32 #vbat
waclawek.jan
Apr 11, 2018 3:53 PM UTC
Posted on April 11, 2018 at 17:53
If no battery, both RM0091 and AN4080 recommend to connect it to VDD.
re.wolff9
re.wolff9Author
Senior
Apr 11, 2018 8:08 PM UTC
Posted on April 11, 2018 at 20:08
Well, yes. You're right. But I was hoping I would not need extra components when I don't mount the battery. Or what if I do mount the battery-holder, but the user forgets to replace the battery when it's empty? That creates a very similar situation as what I have now: Simply a floating VBAT.
I just checked the 'decoupling your STM32F0xx' section in the datasheet. No capacitor on VBAT. And then RM0091 says to install a capacitor when connecting to VDD...
waclawek.jan
Apr 11, 2018 9:28 PM UTC
Posted on April 11, 2018 at 21:28
I guess you can leave it unconnected as long as you don't use the RTC and other VBAT-related features.
Note that I am not ST so do this on your own risk.
T J
Senior III
Apr 11, 2018 10:12 PM UTC
Posted on April 12, 2018 at 00:12
use a jumper or solder blob under the battery itself.
if the battery is not installed, you must solder the blob , shorting out the Vbat to VDD
