JMP.1
Can anyone provide some reference or sample regarding i2c slave bitbang implementation in stm32
  • February 7, 2023
  • 13 replies
  • 4762 views
Foued_KH
Hello @JMP.1​ ,
You can refer to the I2C WIKI : Getting started with I2C - stm32mcu
Hope my answer helped you!
Foued
JMP.1
JMP.1Author
thanks for your reply, this post is helpful when iam doing this i2c with hardware module support. i need to implement software i2c for slave
Foued_KH
Hello @JMP.1​ ,
Please check this link . It will help you to implement software I2C for slave.
Foued
S.Ma
Principal
February 7, 2023
I tried, using Timer and EXTI. It barely works at 200kHz if there is no other interrupt in the STM32.
So my piece of advice: Keep away from trying this.
JMP.1
JMP.1Author
Could you please share that code, i can just try atleast
S.Ma
Principal
March 1, 2023
Well, you have been warned.. STM32F437 code extract. EXTI on both SDA and SCL, plus a slave state machine interrupt based to grasp the I2C bus bit events, and a spy which put in BV (SW fifo) all the I2C seen events as an ASCII String.
S.Ma
Principal
March 1, 2023
S.Ma
Principal
March 1, 2023
S.Ma
Principal
March 1, 2023
S.Ma
Principal
March 1, 2023
S.Ma
Principal
March 1, 2023
S.Ma
Principal
March 1, 2023
InsignificantBit
You might want to look at the AN4655 - "Virtually increasing the number of serial communication peripherals in STM32 applications".
Obviously, there are numerous open source libraries written by people not affiliated with ST that serve this purpose and available on GitHub and elsewhere.
