vincenthamp9
[Bug] STM32CubeMX, SAI->xSLOTR, SLOTEN not shifted
  • January 20, 2016
  • 4 replies
  • 898 views
Posted on January 20, 2016 at 13:50
After spending an entire morning figuring out why my SAI configuration isn't working anymore I guess I found a new bug concerning the configuration of the SLOTR register inside HAL_SAI_Init.
Prior to 1.2.0
hsai->Instance->SLOTR|= hsai->SlotInit.FirstBitOffset | hsai->SlotInit.SlotSize
| (hsai->SlotInit.SlotActive <<
16
) | ((hsai->SlotInit.SlotNumber - 1) << 8);
1.2.0
| hsai->SlotInit.SlotActive | ((hsai->SlotInit.SlotNumber - 1) << 8);
The missing shift at the SlotActive parameter causes the SLOTEN value to be set to a wrong value. Maybe the shift was left out intentinally but the CubeMX tool still produces the same output for the old and the current library version. /edit This was like the 5th bug I reported within 6 months. You guys should put up some kind of reward system for reporting stuff and send me a coffee cup or something. :D
    Nesrine M_O
    Posted on January 20, 2016 at 15:06
    Hi Vinci,
    Could you precise in which HAL library you have found the issue. So, we can verify it.
    -Syrine-
    vincenthamp9
    Posted on January 20, 2016 at 17:09
    Ah damn it, I knew I'd forgotten something :p
    It's concerning the L4-library.
    Nesrine M_O
    Posted on January 20, 2016 at 18:00
    Hi Vinci,
    It is a known bug, and it is already fixed in the STM32CubeL4 version 1.2.0
    -Syrine-
    vincenthamp9
    Posted on January 21, 2016 at 12:48
    You're right I'm sorry!
    My bad, I got mixed up between two commits where the library got updated!
