BSP LIBRARY IAR WORKBENCH STM32F303VC
Posted on January 22, 2018 at 14:00
Good evening,
I can't import BSP library in IAR Workbench. I'm using stm32f303vc board and I'm followed this guide but i have always the same problem(
https://community.st.com/docs/DOC-1500-how-to-add-a-bsp-on-top-of-cubemx-421-generated-code
). I want to begin with CubeMx and after import BSP library to use the sensor installed on the board. Can you help me? Have you got another guide or any suggestion? The problem is: Error[Li005]: no definition for etc.Thank you.
