Posted on May 24, 2016 at 17:43The empty XML was a random response from the server during one login attempt. The sign in sometimes requires two attempts, ie you submit once, and the same login comes back again.
Still habitually seeing this if attempting to reply to a post while not currently logged in. I don't think I've ever got to a login screen via this route since the forum was tinkered with the other week or so. Only thing working is the site level login.
Proxy ErrorThe proxy server received an invalid response from an upstream server.
The proxy server could not handle the request
/cas/login
Reason: Error reading from remote server
