yarona
BootLoader timeout
Posted on January 12, 2015 at 09:17
Hi
I am using STM32L151 bootloader.
I wanted to run the bootloader at program start, and if no usb if attached for a certain time
go back to regular application.
Is it possible to configure a timeout for the bootloader?
Yaron
    January 12, 2015
    Posted on January 12, 2015 at 12:43
    The System Loader (BOOT0=High)? or your own Boot Loader?
    You can decide whether to call the System Loader from your own code, via a button or RAM setting, but it's not going to timeout and come back to you.
    Javier1
    Principal
    January 22, 2025
    How about ST systembootloader, https://community.st.com/t5/stm32-mcus-products/does-system-bootloader-eventually-timeout-and-jump-to-user/td-p/764233
    I have the same question, does it even timeout?
    hit me up in https://www.linkedin.com/in/javiermuñoz/
    urbito
    Senior II
    January 22, 2025
    You are answering for something from 10 years ago i guess.
    But best/easier way to do it, or what i do when needed is, in custom bootloader, put the timeout whenever i need. Never tryed a "non-custom" bootloader!
