Begineer questions
I am just installed the STLink and Yagarto on my Mac OS 10.9.5 and it took me 3 days:( . I started the instance of STLINK by using command :./st-util --stlinkv1
and after that I opened another terminal to run the GDB:tcms-MacBook-Pro:yagarto-4.7.2 Ruslan$ arm-none-eabi-gdb /Users/Ruslans/STM32-Template/BlinkingLight.elf
but when I try to load the .elf by by using command(gdb) target extended-remote :4242
I get this error:Remote debugging using :4242
0x08000b4c in GPIO_Write (GPIOx=0xa, PortVal=<optimized out>)
at /l/arm/STM32F10x_StdPeriph_Lib_V3.5.0/Libraries/STM32F10x_StdPeriph_Driver/src/stm32f10x_gpio.c:423
423 /l/arm/STM32F10x_StdPeriph_Lib_V3.5.0/Libraries/STM32F10x_StdPeriph_Driver/src/stm32f10x_gpio.c: No such file or directory.
I am very new to unix based systems or to GDB and GCC so I have problem with fixing this issue. Could someone advice on how to address this problem? I started by loading the STM32VL library into my project folder STM32 Template but the error persists. I don't understand why gdb is looking for thestm32f10x_gpio.c since the .elf file is already a compiled and ready to be loaded object. Please help.
