RK.15
B-U585I-IOT02A with MX25LM51245G to store and retrieve .bin file using filex and levelx.
Hello ST community,
I am developing an application based on B-U585I-IOT02A. In this I am using the MX25LM51245G which is on board NOR flash connected via OCTOSPI. The functionality is to save and retrieve a .bin file from the NOR flash. Please let me know how can we achieve the same.
KDJEM.1
KDJEM.1Best answer
Hello @Community member​ ,
I advise you to get inspired form the Fx_NoR_Write_Read_File example available in STM32CubeU5 package.
This example may help you by following the instructions in the readme file.
Thank you
Kaouthar
KDJEM.1
KDJEM.1Best answer
Thank you
Kaouthar
February 28, 2023
With FatFS we'd use 4KB sectors to match the erase sector/page size of the QSPI/OSPI devices.
NOR Flash isn't particularly fast, and writes will require an erase.
