arun balaji
March 23, 2018
B-LCD40-DSI1 daughterboard driver code
  • March 23, 2018
  • 5 replies
  • 1183 views
Posted on March 23, 2018 at 09:15
For mipi DSI validation using the B-LCD40-DSI1  daughterboard.
We need the driver code and mipi panel controller register configuration for this mipi panel.
    Andrew Neil
    Posted on March 23, 2018 at 09:21
    You realise that this is essentially a user-to-user forum?
    If you want direct, priority support then you need to contact your ST or Distributor FAE
    Please respond us as soon as possible
    http://www.catb.org/~esr/faqs/smart-questions.html#urgent
    We are validating the (sic) SoC in FPGA platform
    What SoC ?
    What 'FPGA platform' ?
    we need LCD controller datasheet
    So contact the LCD controller manufacturer?
    EDIT
    This:
    http://www.st.com/en/development-tools/b-lcd40-dsi1.html
    March 23, 2018
    Posted on March 23, 2018 at 13:24
    STM32Cube_FW_F7_V1.9.0\Drivers\BSP\STM32F769I-Discovery\stm32f769i_discovery_lcd.c
    STM32Cube_FW_F7_V1.9.0\Drivers\BSP\Components\otm8009a\otm8009a.c
    viswanath reddy
    March 26, 2018
    Posted on March 26, 2018 at 09:04
    Hi Clive One,
    Thanks for your reply.
    we are not using any STM Evaluation boards, we are using the only MIPI-DSI LCD Panel.For this MIPI DSI LCD Panel do we need driver ?
    what ever you suggested c files
    This c file contains bridge chip (
    ADV7533)
    configuration and DSI to HDM adapter code.
    But we are using the another DSI Controller , we implemented the driver for
    DSI Controller but Panel we did not configured ant thing. Really is required driver for Panel.
    Viswa
    Andrew Neil
    Posted on March 26, 2018 at 12:23
    Are you suing any STM32 at all?
    What is provided by ST is in the files
    Turvey.Clive.002
    ‌ mentioned.
    If youcan't work from there, then you're going to have to contact the panel manufacturer for support ...
