Jin ho An
Aug 23, 2017 9:11 AM UTC
B-L072Z-LRWAN1, CubeMX project
Posted on August 23, 2017 at 11:11
Hi.
I am analyzing with B-L072Z-LRWAN1.
If you have a CubeMX project file, it will help you analyze it.
Can not convert AT_Slave project to CubeMX project?
Clock, and LPUART settings.
Please.
    Aug 23, 2017 12:07 PM UTC
    Posted on August 23, 2017 at 14:07
    You will need to merge/refactor the code at a HAL level
    Jin ho An
    Jin ho AnAuthor
    Aug 24, 2017 4:39 AM UTC
    Posted on August 24, 2017 at 04:39
    Thank you for your reply.
    Can I make 'End Code' instead of 'AT_Slave'?
    Aug 24, 2017 5:28 AM UTC
    Posted on August 24, 2017 at 05:28
    Not sure exactly what that is, but most use cases that I see and discuss with people are ones using the L072Z as the sole micro-controller in the design, and it doesn't need to talk in AT commands to itself. So the AT command layer is stripped out, and you just call the underlying functions directly to achieve the desired connectivity.
