Avalonia UI?
Hi All -
Not sure if this is the right place to ask this, but thought I would try anyway.
I just finished a project that used Avalonia UI (C# based cross platform system for application GUIs) on a raspberry-pi 4 with a Waveshare touch screen attached.  It worked very well. :)  It now looks like I'll be starting on another project that needs a UI too but runs on an STM32 MCU based system.
Has anyone tried Avalonia UI on their system?  Did it even work?
Curious if there are others who have done this before I start down this path.
Thanks!
Peter BENSCH
Peter BENSCHBest answer
Welcome @clawton, to the community!
If you take a look at the list of platforms supported by Avalonia UI, you will be able to confirm that only MPUs can be found there. Your question about support for an MCU platform should be redundant, right?
/Peter
Peter BENSCH
/Peter
clawtonAuthor
Thank you for responding.  Actually meant MPU! Why I typed MCU, I'll never know. :grimacing_face:
