chai
Assign Value on STM32
  • August 27, 2012
  • 691 views
Posted on August 27, 2012 at 22:25
I used
uint8_t CSD_Tab[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
to initialize an array. But when I use IAR EWARM to watch the content in this array, the value is always unchanged. Any ideas?
Thank you
    chai
    chaiAuthor
    Posted on August 27, 2012 at 22:43
    OK, I just figure it out. I did not allocate the RAM memory for it.
    frankmeyer9
    Posted on August 28, 2012 at 09:26
    Not quite true.
    With  ''uint8_t CSD_Tab[16] '' you did actually allocate that array.
    Perhaps you never changed it's contents, or the IAR compiler optimized it out.
    Trying to learn both C and microcontrollers at the same time could become difficult and frustrating ...
