Are stm32g431 and stm32g441 pin compatible?
As I've seen in cubeMX all periphereals I use match the same pins in both versions of x1 series (which vary just in the absence of AES encryption module) but I cannot find in any datasheet wether they truly are as it is not mentioned anywhere as far as I can tell
