relaxe
Nov 12, 2008 11:53 AM UTC
Anybody have a code for SDHC over SDIO?
Posted on November 12, 2008 at 12:53
    relaxe
    relaxeAuthor
    May 17, 2011 10:52 AM UTC
    Posted on May 17, 2011 at 12:52
    I've been working with the sdcard demo code for reading/writing to the SDcard. However, this code does not seem to handle SDHCs.
    Do someone have a code/module ready to R/W SDHC with the high-density devices SDIO?
    Thanks!
    16-32micros
    Dear jj,
    Ye, Indeed ! I'm referring to micro SD... Sorry my limited details :)
    Cheers,
    ST {1+3=2} :)
    jj_it
    STOne-32-
    This is good news - thank you.
    Do you know if Micro SDHC - by same makers you specified - will also work?
    Regards,
    jj
    16-32micros
    Dear Relaxe,
    You can refer this demo from ST
    http://www.st.com/stonline/products/support/micro/files/um0549.zip
    there is a Mass storage example that supports SDHC SDIO memory cards, I have tested 2 SD cards SDHC more than 4Gbytes ( Sandisk and Verbatim) and working fine. Hope this helps you.
    Cheers,
    STOne-32.
