Analog Watchdog to trigger on offset adc value
I am applying 4 offset to 4 adc channels and calculating the analog watchdog high threshold based on a threshold above the highest adc channel. The purpose of the adc offsets is to equalize the channels readings, such that the adc watchdog high threshold will be the same delta above any of the four channels. The issue I am having is the analog watchdog is triggering on the non-offset values. For instance, if my 4th channel is 0.1V above the 1st channel, before an offset is applied, and I set the watchdog to 0.1V, I get a constant trigger. With the offset applied, the 1st channel equals the 4th channel, but the watchdog is trigger based on the pre-offset values. To summarize, it seems that the analog watchdog triggers on adc readings before the offset is applied. Is there a way to get it to trigger post offset?
