sheng yang
Senior
January 20, 2024
after set stm32g070 pll N parameter, chip cann't connect with stlink.
I modified sys clock config as
```C
void SystemClock_Config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
/** Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
/* RCC_OscInitStruct.LSIState = RCC_LSI_OFF; */
RCC_OscInitStruct.HSIDiv = RCC_HSI_DIV1;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV1;
RCC_OscInitStruct.PLL.PLLN = 32;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
Error_Handler();
|RCC_CLOCKTYPE_PCLK1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
after I do this ,I cann't connect stm32g070cbt6 now ,is the chip broken
AScha.3
AScha.3Best answer
What is your programmer ? ( st-link V2 "sticks"  might not work here.)
Use stm32CubeProgrammer ->
Try to connect "under reset" -
or try starting bootloader (boot0 = hi) -
then load a program with correct clock/pll settings.
sheng yang
Senior
January 20, 2024
as you can see I set PLLN to 32 accidentally..:frowning_face:
AScha.3
AScha.3Best answer
sheng yang
Senior
January 20, 2024
I use st-link v2, and I do with like https://blog.csdn.net/Yetty1990/article/details/121610677 to slove this issue. tks for youe reply.
