AES for hashing
For some reason I need to use the AES engine to generate hashing either as ghash or AES-CMAC digest. Any reference could you provide to use AES engine for MAC generation.
Thanks,
Gopi Krishnan
I tried to generate the code from CubeMX with AES GHASH option, but the generated code has only AES init. It does not has sample code to load key and generate hash for given message.
Any source would be helpful.
Thanks,
Billy OWEN
Hi @gopikrishnan
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Regards,
Billy
@Billy OWEN , I haven't heard from you for a long. Can we expect a reply.
