worlag
adding regular function to the _it.c file
  • April 1, 2014
  • 787 views
Posted on April 01, 2014 at 16:44
hi,
i added a function ( not an ISR )  to the stm32f4xx_it.c file.
when i call it from main() i couldn't program the .elf file to the target ( using the segger )  getting ''no source available for 0x0''.
does someone know why is it ?
thanks
Ari
    April 1, 2014
    Posted on April 01, 2014 at 16:52
    Did it link properly without an error? Can you see the function in the map and/or listing files?
    worlag
    worlagAuthor
    Posted on April 01, 2014 at 17:21
    thanks.
    well, the problem not happening right  now..though i don't know which change fix the problem..
