ADC with DMA and 3 Channels
i'm trying to get a 3 channel dma up and running on my u5, but unfortunately i keep getting the error handler at line 122 that the a/d can't start via dma. do i need to do something additional here or not? i've already clicked through some posts and tried to configure my a/d directly, but unfortunately that didn't quite work. i'm currently working on a stmu599.
// DEFINES
#define DEBUG_DRV_adc
#if defined (DEBUG) && defined (DEBUG_DRV_GPDMA)
#define DBG(format, ...) printf("drv_adc: " format "\n", ##__VA_ARGS__)
#else
#define DBG(...)
#endif
// TYPEDEFS
// VARIABLES
ADC_HandleTypeDef hadc1;
DMA_NodeTypeDef Node_GPDMA1_Channel6;
DMA_QListTypeDef List_GPDMA1_Channel6;
DMA_HandleTypeDef handle_GPDMA1_Channel6;
static uint32_t ADCvalue[3]; // to store the adc values
static bool initialized = false;
// PROTOTYPES
// FUNCTIONS
void drv_ADC1_Init(void)
if(initialized)
return;
 /* USER CODE BEGIN ADC1_Init 0 */
 /* USER CODE END ADC1_Init 0 */
 ADC_ChannelConfTypeDef sConfig = {0};
 /* USER CODE BEGIN ADC1_Init 1 */
 /* USER CODE END ADC1_Init 1 */
 /** Common config
 hadc1.Instance = ADC1;
 hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV4;
 hadc1.Init.Resolution = ADC_RESOLUTION_12B;
 hadc1.Init.GainCompensation = 0;
 hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
 hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
 hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
 hadc1.Init.LowPowerAutoWait = DISABLE;
 hadc1.Init.ContinuousConvMode = ENABLE;
 hadc1.Init.NbrOfConversion = 3;
 hadc1.Init.DiscontinuousConvMode = DISABLE;
 hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
 hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
 hadc1.Init.DMAContinuousRequests = DISABLE;
 hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_LOW;
 hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
 hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
 hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DMA_CIRCULAR;
 hadc1.Init.OversamplingMode = DISABLE;
 if (HAL_ADC_Init(&hadc1) != HAL_OK)
 Error_Handler();
 /** Configure Regular Channel
 sConfig.Channel = ADC_CHANNEL_5;
 sConfig.Rank = ADC_REGULAR_RANK_1;
 sConfig.SamplingTime = ADC_SAMPLETIME_5CYCLE;
 sConfig.SingleDiff = ADC_SINGLE_ENDED;
 sConfig.OffsetNumber = ADC_OFFSET_NONE;
 sConfig.Offset = 0;
 if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_7;
 sConfig.Rank = ADC_REGULAR_RANK_2;
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_17;
 sConfig.Rank = ADC_REGULAR_RANK_3;
 Error_Handler();
 if (HAL_ADCEx_Calibration_Start(&hadc1, ADC_CALIB_OFFSET_LINEARITY, ADC_SINGLE_ENDED) !=HAL_OK)
 Error_Handler();
 initialized = true;
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
 DMA_NodeConfTypeDef NodeConfig= {0};
 RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
 if(adcHandle->Instance==ADC1)
 /* USER CODE BEGIN ADC1_MspInit 0 */
 /* USER CODE END ADC1_MspInit 0 */
 /** Initializes the peripherals clock
 PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADCDAC;
 PeriphClkInit.AdcDacClockSelection = RCC_ADCDACCLKSOURCE_HSI;
 if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
 Error_Handler();
 /* ADC1 clock enable */
 __HAL_RCC_ADC12_CLK_ENABLE();
 __HAL_RCC_GPIOA_CLK_ENABLE();
 __HAL_RCC_GPIOB_CLK_ENABLE();
 /**ADC1 GPIO Configuration
 PA0 ------> ADC1_IN5
 PA2 ------> ADC1_IN7
 PB2 ------> ADC1_IN17
 GPIO_InitStruct.Pin = ADC_VUNREG_Pin|ADC_VIN_Pin;
 GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
 GPIO_InitStruct.Pin = ADC_VBUS_Pin;
 HAL_GPIO_Init(ADC_VBUS_GPIO_Port, &GPIO_InitStruct);
 /* ADC1 DMA Init */
 /* GPDMA1_REQUEST_ADC1 Init */
 NodeConfig.NodeType = DMA_GPDMA_LINEAR_NODE;
 NodeConfig.Init.Request = GPDMA1_REQUEST_ADC1;
 NodeConfig.Init.BlkHWRequest = DMA_BREQ_SINGLE_BURST;
 NodeConfig.Init.Direction = DMA_PERIPH_TO_MEMORY;
 NodeConfig.Init.SrcInc = DMA_SINC_FIXED;
 NodeConfig.Init.DestInc = DMA_DINC_INCREMENTED;
 NodeConfig.Init.SrcDataWidth = DMA_SRC_DATAWIDTH_WORD;
 NodeConfig.Init.DestDataWidth = DMA_DEST_DATAWIDTH_WORD;
 NodeConfig.Init.SrcBurstLength = 1;
 NodeConfig.Init.DestBurstLength = 1;
 NodeConfig.Init.TransferAllocatedPort = DMA_SRC_ALLOCATED_PORT0|DMA_DEST_ALLOCATED_PORT1;
 NodeConfig.Init.TransferEventMode = DMA_TCEM_BLOCK_TRANSFER;
 NodeConfig.Init.Mode = DMA_NORMAL;
 NodeConfig.TriggerConfig.TriggerPolarity = DMA_TRIG_POLARITY_MASKED;
 NodeConfig.DataHandlingConfig.DataExchange = DMA_EXCHANGE_NONE;
 NodeConfig.DataHandlingConfig.DataAlignment = DMA_DATA_RIGHTALIGN_ZEROPADDED;
 if (HAL_DMAEx_List_BuildNode(&NodeConfig, &Node_GPDMA1_Channel6) != HAL_OK)
 Error_Handler();
 if (HAL_DMAEx_List_InsertNode(&List_GPDMA1_Channel6, NULL, &Node_GPDMA1_Channel6) != HAL_OK)
 Error_Handler();
 if (HAL_DMAEx_List_SetCircularMode(&List_GPDMA1_Channel6) != HAL_OK)
 Error_Handler();
 handle_GPDMA1_Channel6.Instance = GPDMA1_Channel6;
 handle_GPDMA1_Channel6.InitLinkedList.Priority = DMA_LOW_PRIORITY_LOW_WEIGHT;
 handle_GPDMA1_Channel6.InitLinkedList.LinkStepMode = DMA_LSM_FULL_EXECUTION;
 handle_GPDMA1_Channel6.InitLinkedList.LinkAllocatedPort = DMA_LINK_ALLOCATED_PORT0;
 handle_GPDMA1_Channel6.InitLinkedList.TransferEventMode = DMA_TCEM_BLOCK_TRANSFER;
 handle_GPDMA1_Channel6.InitLinkedList.LinkedListMode = DMA_LINKEDLIST_CIRCULAR;
 if (HAL_DMAEx_List_Init(&handle_GPDMA1_Channel6) != HAL_OK)
 Error_Handler();
 if (HAL_DMAEx_List_LinkQ(&handle_GPDMA1_Channel6, &List_GPDMA1_Channel6) != HAL_OK)
 Error_Handler();
 __HAL_LINKDMA(adcHandle, DMA_Handle, handle_GPDMA1_Channel6);
 if (HAL_DMA_ConfigChannelAttributes(&handle_GPDMA1_Channel6, DMA_CHANNEL_NPRIV) != HAL_OK)
 Error_Handler();
 HAL_NVIC_SetPriority(ADC1_2_IRQn, 5, 0);
 HAL_NVIC_EnableIRQ(ADC1_2_IRQn);
 /* USER CODE BEGIN ADC1_MspInit 1 */
 /* USER CODE END ADC1_MspInit 1 */
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
 /* Peripheral clock disable */
 __HAL_RCC_ADC12_CLK_DISABLE();
 HAL_GPIO_DeInit(GPIOA, ADC_VUNREG_Pin|ADC_VIN_Pin);
 HAL_GPIO_DeInit(ADC_VBUS_GPIO_Port, ADC_VBUS_Pin);
 /* ADC1 DMA DeInit */
 HAL_DMA_DeInit(adcHandle->DMA_Handle);
void drv_ADC_Start ()
if(HAL_OK != HAL_ADC_Start_DMA(&hadc1, ADCvalue, 3))
DBG( "DMA Start ERROR", result );
Error_Handler();
DBG( "ADC DMA Start", result );
Christian N
This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
