Ngai yuk kong
May 4, 2018 5:47 AM UTC
ADC sample rate
Posted on May 04, 2018 at 07:47
Hi all,
I have seven adc channels to convert using STM32F051. I set the ADC to be triggered by timer 15. I also setup DMA to put all the converted results to a memory buffer and have a Transfer complete interrupt set.
Here is the setting:
Timer 15 using 100KHz
ADC set to complete whole sequence
DMA in circular mode
Everything work except that when I toggle a I/O inside the DMA interrupt, I got the frequency around 5KHz.
Any direct correlation between this 5KHz with my timer 100KHz? The MCU specification has a diagram showing that during the conversion the timer trigger will be ignored until all the conversion is complete. Does it mean that there is no way to control the sampling rate????
Many thanks..
    T J
    Senior III
    May 4, 2018 6:16 AM UTC
    Posted on May 04, 2018 at 08:16
    There is several factors for the ADC timing.
    ADC prescaler (don't use 1 or 2 even 4 may be noisy)
    ADC Sample rate (don't use fastest or second fastest for better stability), you can test this.
    DMA channels is 7
    Timer to trigger initial sample/DMA system.  ( should be set to 1KHz, then go faster if you need to)
    So the timer should be set to more than 7x less than the sample rate.
    5KHz will be 7x your current sample rate.
    ie 1/35KHz shows you have a 28uS conversion rate per channel.
    Ngai yuk kong
    May 4, 2018 6:31 AM UTC
    Posted on May 04, 2018 at 08:31
    Sorry bro I still cannot understand.
    i found something strange as well....when i set my timer to 1Hz, I suppose the DMA interrupt will follow this timer frequency.....however, the result shows that my pin toggling inside the DMA interrupt can be up to 60Hz.................
    Ngai yuk kong
    May 4, 2018 8:48 AM UTC
    Posted on May 04, 2018 at 08:48
    My fault for the 60Hz, it is due to my wrong setting in the 16 bit register.........sorry about that
    Ngai yuk kong
    May 4, 2018 7:28 AM UTC
    Posted on May 04, 2018 at 09:28
    I understand that the DMA is not able to catch up the very high timer speed since the operation involves channel switching. My original question is just want to know if there any way to calculate the actual sampling frequency. The very reason I want to know is, I need to sample AC input voltage and calculate the rms voltage but my colleague keeps saying it will not be accurate to sample using this method. He is using Microchip and has several ADC cores to sample in parallel. For STM32F051, there is only one ADC core and we need to switch channels.
    If you guys have good method to sample half period AC voltage (the negative side of sine wave will flip to positive) and then do the rms calculation please share with me as well. Right now I am reading seven channels in one scan using DMA interrupt and timer trigger.
    Many thanks to all of you, even for spending time reading my questions...
    AvaTar
    Senior III
    May 4, 2018 11:44 AM UTC
    Posted on May 04, 2018 at 11:44
    I understand that the DMA is not able to catch up the very high timer speed ...
    DMA is not your problem I think.Rather your method.
    When triggering the ADC, it triggers the configured sequence. And I see two problems here. Seven channels in less than 10us (1/100kHz) is challenging, at least accuracy-wise.
    But more important, the samples are not equidistant. The sequence start depends on the timer setting, but the delay between channels on your ADC sample time configuration.
    Perhaps you can get away with one channel and continuous mode, instead of time-triggered sequences.
    What frequency does the input waveform have, 50/60Hz mains ?
    Ngai yuk kong
    May 7, 2018 8:41 AM UTC
    Posted on May 07, 2018 at 08:41
    After changing the ADC clock to be PCLK/2 (24MHz) and the ADC sampling time to be 13.5 ADC clock cycles, 100KHz seems to be achievable. However, another concern about the accuracy is really unknown to me. The range can be selected from 1.5 ADC cycle  up to 239.5 ADC cycles. How to choose the correct one?
    T J
    Senior III
    May 4, 2018 7:52 AM UTC
    Posted on May 04, 2018 at 09:52
    Did you use the cube ?
    in the cube, you can select the ADC speed from 1.5cycles to 239.5 cycles. I would start at 13.5 @14Mhz is approx 1uS per conversion, it may be unstable, see how you go.
    I think you could select 1 channel and use the DMA read it continuously into a circular buffer of your calculation length.
    for the best RMS reading
    seems there is no clock selection in the 'F051  you have a 14MHz clock.
    Ngai yuk kong
    May 4, 2018 9:55 AM UTC
    Posted on May 04, 2018 at 09:55
    I am not using Cube. I have total 7 ADC inputs have to be served. The fastest ADC clock I can set is Fclk/2 inside ADC_CFGR2 register.
    T J
    Senior III
    May 4, 2018 10:03 AM UTC
    Posted on May 04, 2018 at 10:03
    still 1uS per channel at the fastest and stable, you can play around after you have ot running.
    There is a ADC cycles selection, 1.5 to 239.5 cycles,
    you can select the 2nd or 3rd fastest, you have to test the stability.
    so at 13.5 Cycles, its 1uS, 7uS for all 7 channels,
    just run it flat out, get rid of the timer if you can. make the dma run continuously.
    you should check the cube, did you check any examples ?
    I haven't used an 'F051, so you should check the reference manual.
    AvaTar
    Senior III
    May 4, 2018 8:45 AM UTC
    Posted on May 04, 2018 at 10:45
    Usually, one would configure DMA to create a TC interrupt after each sequence, i.e. 7 values in your case.
    It is probably useful to show the relevant code here.
    Ngai yuk kong
    May 4, 2018 11:57 AM UTC
    Posted on May 04, 2018 at 11:57
    Yes, below is my code:
    //20us
    ♯ define TIMER15_PERIOD_TICKS 20
    static hwtmr_handle_t timer15,
    ♯ define HWTMR15_CK_CNT 1000000.0 /* 1us tick */
    ♯ define HWTMR15_CLK \
    (cpu_GetSpeed() / CONFIG_CPU_PCLK1_PRESCALER * \
    ((CONFIG_CPU_PCLK1_PRESCALER == 1) ? 1 : 2))
    ♯ define HWTMR15_PRESCALER (unsigned) (HWTMR15_CLK / HWTMR15_CK_CNT - 1)
    void adcApp_Init(void)
    DMA_Channel_TypeDef *dma = DMA1_Channel1,
    timer15.device = TIM15,
    timer15.config.clock_prescaler = HWTMR15_PRESCALER,
    hwtmr_Init(&,timer15),
    TIM15->,CR2 |= TIM_CR2_MMS_1,
    hwtmr_StartRecurring(&,timer15, TIMER15_PERIOD_TICKS),
    ADC1->,CFGR1 =
    _VAL2FLD(ADC_CFGR1_DISCEN, 0) | // whole sequence at once
    _VAL2FLD(ADC_CFGR1_AUTOFF, 0) |
    _VAL2FLD(ADC_CFGR1_WAIT, 0) |
    _VAL2FLD(ADC_CFGR1_CONT, 0) |
    _VAL2FLD(ADC_CFGR1_OVRMOD, 0) |
    _VAL2FLD(ADC_CFGR1_EXTEN, 1) |
    _VAL2FLD(ADC_CFGR1_EXTSEL, 4) |
    _VAL2FLD(ADC_CFGR1_ALIGN, 0) | // data right aligned
    _VAL2FLD(ADC_CFGR1_RES, 0) | // 12 bit resolution
    _VAL2FLD(ADC_CFGR1_SCANDIR, 0) | // upward scan
    _VAL2FLD(ADC_CFGR1_DMACFG, 1) | // DMA circular mode
    _VAL2FLD(ADC_CFGR1_DMAEN, 1), // DMA enabled
    ADC1->,CFGR2 = _VAL2FLD(ADC_CFGR2_CKMODE, 1),
    // sampling time set to maximum:
    ADC1->,SMPR = _VAL2FLD(ADC_SMPR_SMP, 7),
    ADC1->,CHSELR =
    ADC_CHSELR_CHSEL0 //PA0
    | ADC_CHSELR_CHSEL2 //PA2
    | ADC_CHSELR_CHSEL3 //PA3
    | ADC_CHSELR_CHSEL6 //PA6
    | ADC_CHSELR_CHSEL7 //PA7
    | ADC_CHSELR_CHSEL8 //PB0
    | ADC_CHSELR_CHSEL9, //PB1
    // Set up DMA transfer from ADC to program data memory.
    dma->,CCR =
    _VAL2FLD(DMA_CCR_MEM2MEM, 0) |
    _VAL2FLD(DMA_CCR_PL, 0) | // low priority
    _VAL2FLD(DMA_CCR_MSIZE, 2) | // 32 bit memory size
    _VAL2FLD(DMA_CCR_PSIZE, 2) | // 32 bit peripheral size
    _VAL2FLD(DMA_CCR_MINC, 1) | // memory increment enabled
    _VAL2FLD(DMA_CCR_PINC, 0) | // peripheral increment disabled
    _VAL2FLD(DMA_CCR_CIRC, 1) | // circular mode
    _VAL2FLD(DMA_CCR_DIR, 0) | // from peripheral to memory
    _VAL2FLD(DMA_CCR_TCIE, 1),
    dma->,CNDTR = NO_OF_ADC,
    dma->,CPAR = (uintptr_t) &,ADC1->,DR,
    dma->,CMAR = (uintptr_t) adc_raw,
    cfp_SetBit(&,(DMA1_Channel1)->,CCR, DMA_CCR_EN),
    cpu_EnableInterrupt(DMA1_Channel1_IRQn),
    enableAdc(),
    startAdcConversion(),
    void DMA1_Channel1_IRQHandler(void)
    if(DMA1->,ISR &, DMA_ISR_TCIF1)
    DMA1->,IFCR = DMA_IFCR_CTCIF1 | DMA_IFCR_CHTIF1 | DMA_IFCR_CGIF1,
    digio_ToggleOutputValue(GPIOB, 14),
    T J
    Senior III
    May 4, 2018 12:08 PM UTC
    Posted on May 04, 2018 at 12:08
    the Cube does this for me...
    /* ADC init function */
    void MX_ADC_Init(void)
     ADC_ChannelConfTypeDef sConfig;
     /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
     hadc.Instance = ADC1;
     hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
     hadc.Init.Resolution = ADC_RESOLUTION_12B;
     hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
     hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
     hadc.Init.EOCSelection = ADC_EOC_SEQ_CONV;
     hadc.Init.LowPowerAutoWait = DISABLE;
     hadc.Init.LowPowerAutoPowerOff = DISABLE;
     hadc.Init.ContinuousConvMode = DISABLE;
     hadc.Init.DiscontinuousConvMode = DISABLE;
     hadc.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T15_TRGO;
     hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_RISING;
     hadc.Init.DMAContinuousRequests = ENABLE;
     hadc.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
     if (HAL_ADC_Init(&hadc) != HAL_OK)
     _Error_Handler(__FILE__, __LINE__);
     /**Configure for the selected ADC regular channel to be converted.
     sConfig.Channel = ADC_CHANNEL_0;
     sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
     sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
     if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
     sConfig.Channel = ADC_CHANNEL_5;
     sConfig.Channel = ADC_CHANNEL_6;
     sConfig.Channel = ADC_CHANNEL_7;
     sConfig.Channel = ADC_CHANNEL_8;
     sConfig.Channel = ADC_CHANNEL_9;
     sConfig.Channel = ADC_CHANNEL_13;
     sConfig.Channel = ADC_CHANNEL_14;
     sConfig.Channel = ADC_CHANNEL_15;
     sConfig.Channel = ADC_CHANNEL_TEMPSENSOR;
     sConfig.Channel = ADC_CHANNEL_VREFINT;
     sConfig.Channel = ADC_CHANNEL_VBAT;
    void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
     GPIO_InitTypeDef GPIO_InitStruct;
     if(adcHandle->Instance==ADC1)
     /* USER CODE BEGIN ADC1_MspInit 0 */
     /* USER CODE END ADC1_MspInit 0 */
     /* ADC1 clock enable */
     __HAL_RCC_ADC1_CLK_ENABLE();
     /**ADC GPIO Configuration
     PC3 ------> ADC_IN13
     PA0 ------> ADC_IN0
     PA5 ------> ADC_IN5
     PA6 ------> ADC_IN6
     PA7 ------> ADC_IN7
     PC4 ------> ADC_IN14
     PC5 ------> ADC_IN15
     PB0 ------> ADC_IN8
     PB1 ------> ADC_IN9
     GPIO_InitStruct.Pin = CurrentSense_Pin|RS6_Pin|RS7_Pin;
     GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
     HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
     GPIO_InitStruct.Pin = RS8_Pin|RS5_Pin|RS1_Pin|RS2_Pin;
     GPIO_InitStruct.Pin = RS3_Pin|RS4_Pin;
     /* ADC1 DMA Init */
     /* ADC Init */
     hdma_adc.Instance = DMA1_Channel1;
     hdma_adc.Init.Direction = DMA_PERIPH_TO_MEMORY;
     hdma_adc.Init.PeriphInc = DMA_PINC_DISABLE;
     hdma_adc.Init.MemInc = DMA_MINC_ENABLE;
     hdma_adc.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
     hdma_adc.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
     hdma_adc.Init.Mode = DMA_CIRCULAR;
     hdma_adc.Init.Priority = DMA_PRIORITY_LOW;
     if (HAL_DMA_Init(&hdma_adc) != HAL_OK)
     __HAL_DMA1_REMAP(HAL_DMA1_CH1_ADC);
     __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc);
     /* USER CODE BEGIN ADC1_MspInit 1 */
     /* USER CODE END ADC1_MspInit 1 */
    void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
     /* USER CODE BEGIN ADC1_MspDeInit 0 */
     /* USER CODE END ADC1_MspDeInit 0 */
     /* Peripheral clock disable */
     __HAL_RCC_ADC1_CLK_DISABLE();
     PA0 ------> ADC_IN0
     PA5 ------> ADC_IN5
     PA6 ------> ADC_IN6
     PA7 ------> ADC_IN7
     PB0 ------> ADC_IN8
     PB1 ------> ADC_IN9
     HAL_GPIO_DeInit(GPIOC, CurrentSense_Pin|RS6_Pin|RS7_Pin);
     HAL_GPIO_DeInit(GPIOA, RS8_Pin|RS5_Pin|RS1_Pin|RS2_Pin);
     HAL_GPIO_DeInit(GPIOB, RS3_Pin|RS4_Pin);
     /* ADC1 DMA DeInit */
     HAL_DMA_DeInit(adcHandle->DMA_Handle);
     /* USER CODE BEGIN ADC1_MspDeInit 1 */
     /* USER CODE END ADC1_MspDeInit 1 */
