vshah
ADC of STM32L4R5ZI controller not able to read below 60mV, Vref = 2.8V and ADC resolution is 12bit
  • September 16, 2019
  • 1 reply
  • 592 views
Below 60mV controller unable to produce ADC output
waclawek.jan
What exactly does the ADC output at such input voltage? Did you try on multiple pins? Does the sampling time setting influence the result?
Do you test this on a "known good" board such as a Nucleo/Disco, or your own board? In the latter case, could you run the test on a Nucleo/Disco?
