Bernardo1947
ADC measurement error on STM32G030KxTx
I am developing a project to take some measurements with ADC channels, however the values are wrong. When I connect any ADC channel direct to GND, it gives me a value about 60~80 (The ADCs are 12-bit precision) and this error propagates for any reading.
How should I solve this problem? Could be any PCB layout noise or is it a problem with ADC reference?
waclawek.jan
waclawek.janBest answer
Did you perform ADC calibration as per instructions in Reference Manual?
waclawek.jan
Bernardo1947
@Community member​ I've set the ADCAL bit and it solved as detailed in the RM, thank you a lot!
