elec_st
Mar 23, 2017 11:06 AM UTC
adc external trigger
Posted on March 23, 2017 at 12:06
i search in google and i can't find any adc external trigger example code i found timer trigger only.
i want adc start conversion when external  pulse found.
i want any example code
    Mar 23, 2017 11:16 AM UTC
    Posted on March 23, 2017 at 12:16
    Which device are you using ?
    To have more insight into ADC applications, I recommend you to check the ADC example in the Cube package relevant to the device that you are using.
    E.g  for STM32CubeF3 firmware package:
    STM32Cube_FW_F3_V1.6.0\Projects\STM32303E_EVAL\Examples\ADC\ADC_TriggerMode
    This example describes how to use the ADC and TIM2 to convert continuously data from ADC channel.
    You have to follow your reference manual  in section Analog-to-digital converters (ADC)
    Hope this help you.
    Imen
    elec_st
    elec_stAuthor
    Mar 23, 2017 12:57 PM UTC
    Posted on March 23, 2017 at 12:57
    i use stm32f103
    you say example use ADC and TIM2 . i not want to use timer.
    i want when external pulse coming i want enable adc start conversion
     i use only one adc channel0.
    reference manual give me adc Artitecture  but  i want how to use it in c/c++ code example.
    Mar 23, 2017 2:12 PM UTC
    Posted on March 23, 2017 at 14:12
    Engineering is not about finding solutions on the Internet.
    For Google to have an example, someone would have to write one and post one, without the help of Google.
    Configure a TIM in Input Capture such that TIMx_CCx matched one of the external trigger settings for the ADC. Find an example in the SPL of doing Input Capture, and modify it, and merge into your ADC code.
    elec_st
    elec_stAuthor
    Mar 23, 2017 2:11 PM UTC
    Posted on March 23, 2017 at 15:11
    ok,
    the problem not in google the problem in stm32 support not give us enough example
    atmel and microchip give you  all peripheral examples .
    stm32 i spend alot of time to make peripheral work.
    i make adc1 external triger.
     hadc1.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_EXT_IT11;
    but when i put a pulse the adc not start conversion .
       if (HAL_ADC_PollForConversion(&hadc1, 1000000) == HAL_OK)
               value= HAL_ADC_GetValue(&hadc1);
    AvaTar
    Senior III
    Mar 23, 2017 3:30 PM UTC
    Posted on March 23, 2017 at 15:30
    ... the problem in stm32 support not give us enough example
    This is not a ST support hotline here, but a public forum.
    The former will charge you for their help, while you can't 'demand' solutions from the latter.
    There are many examples to trigger the ADC by hardware (Timer). And there are many examples on how to config a GPIO.
    Shouldn't be too difficult to combine both.
    I need to agree with Clive - embedded engineering is not about finding almost complete solutions with google.
    You might soon come across a vendor like Cypress, without any public forum at all.
    juozas
    Apr 17, 2018 11:26 AM UTC
    Posted on April 17, 2018 at 13:26
    The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6tX&d=%2Fa%2F0X0000000bxX%2FGEOdNYYEbyqqptcJL980B8wdoL9jF4IB92IFMQNrpK8&asPdf=false
    anaeb.1
    Nov 20, 2023 7:19 PM UTC
    I know it's been a long time but have you found any solution for this ? i have the same problem...
    Nov 20, 2023 7:52 PM UTC
    Yes, you use the plumbing of the TIM's to take an external input, perhaps time-stamp it, but having the knock-on effect of triggering an ADC sample.
    ie if you can use TIM2_CH2 as an ADC Trigger, do an Input Capture on a TIM2 Channel 2, have TIM2 maximal and free-running, and wire your trigger to the external pin associated with TIM2_CH2. This isn't rocket science
    anaeb.1
    Nov 20, 2023 9:09 PM UTC
    haha thank you very much
    unfortunately this is a rakette development for me. i am completely new in this direction and i have it as project work. i have been stuck at this step for 2 months.
    can you perhaps show me the exact configurations for this? i would be very grateful
