Moamen Ayman
Dec 9, 2016 7:51 PM UTC
ADC circuit
Posted on December 09, 2016 at 20:51
I am working on a design on stm32f407vgt6 which I don't want to use the ADC & DAC so I don't have to connect the circuit of ADC and leave VDDA&VSSA&VREF floating?
#clive1
    Lawliet KG
    Lawliet KGBest answer
    Dec 13, 2016 11:04 AM UTC
    Posted on December 13, 2016 at 12:04
    Hi
    Ayman.Moamen
    In the datasheet of the
    stm32f407xx device, section 'Power supply scheme', it's indicated that VSSA and VDDA pins
    MUST
    be
    respectively
    connected to VSS and VDD in order to correctly power on the device; Otherwise, you will be out of specification.
    For the VREF pin, it SHOULD be connected.
    -> So, whether you will be using DAC/ADC peripherals or not, I advice you to correctly connect those pins as indicated on the datasheet.
    If this answers your request, please press 'correct'
    Regards,
    Lawliet.
    Lawliet KG
    Hi
    Ayman.Moamen
    MUST
    be
    respectively
    Regards,
    Lawliet.
