June 10, 2024
Activate preload register for HRTIM in push-pull mode
Recently, I'm studying HRTIM with G4 product. It's known there's a push-pull logic in HRTIM which could output CHx1 and CHx2 alternately to achieve balanced output. I could generate the setting from CubeMX and get push-pull waveform as I wanted. However, I'm still confused about the timing that preload registers was activated?  Is it possible to active roll-over event till a fully cycle (2 PER)?
Roger SHIVELY
Hello @Syl ,
This post has been escalated to the ST Online Support Team for additional assistance.
We'll contact you directly.
Regards,
Roger
