Access ETM only with code without the use of debug kits
My board is Nucleo F401RE.
This is the first time I've ever been doing this.
I am using a pointer to the main registry of ETM, its address I read it on the datasheet.
My problem is that wanting to change the bits of this log I do not change it the correct way.
Thank you
