Scott Shan
Nov 21, 2017 6:12 AM UTC
About Min_Heap_Size and Min_Stack_Size
Posted on November 21, 2017 at 07:12
my STM32F302R8 Device with 64KByte FLASH, 16KByte RAM.
I configured
Min_Heap_Size and Min_Stack_Size in file '
stm32_flash.ld' as below.
_Min_Heap_Size = 0x400;
_Min_Stack_Size = 0x1000;
While build the project codes, below error was happened.
c:/emb_tool/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: ./Release/my_app.elf section `._user_heap_stack' will not fit in region `RAM'
c:/emb_tool/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: region `RAM' overflowed by 96 bytes
collect2.exe: error: ld returned 1 exit status
make: *** [all] Error 1
After changed
_Min_Heap_Size from  0x400 to 0x200, re-bulid it and no more error.
Actually, I didn't know how to figure out the _Min_Heap_Size and _Min_Stack_Size.
Does any expert share the experience how to figure out the
_Min_Heap_Size and
_Min_Stack_Size?
Thanks.
    AvaTar
    AvaTarBest answer
    Senior III
    Nov 21, 2017 6:42 AM UTC
    Posted on November 21, 2017 at 07:42
    Basically, the usage is the same as with compilers in a OS environment.
    Heap is used for allocated memory (malloc, new), and the stack for call parameters and local variables.
    Depending on your project, 1k of heap and 4k of stack seems quite a lot.
    I do rarely use allocated memory, thus heap size is zero for most of my projects.
    Some IDEs start out with a default setting of 128 bytes of stack.
    Strange message - actually, heap and stack alone do fit.
    In most cases, the linker puts heap and stack first, and complains about 'user' variables overflowing.
    AvaTar
    AvaTarBest answer
    Senior III
    Scott Shan
    Nov 28, 2017 4:43 AM UTC
    Posted on November 28, 2017 at 04:43
    Hi AvaTar,
    Thanks a lot.
