wuxiangdong
Dec 20, 2009 9:40 PM UTC
About DFU file
Posted on December 20, 2009 at 22:40
About DFU file
    armmcu
    May 17, 2011 11:34 AM UTC
    Posted on May 17, 2011 at 13:34
    I geuss all what you need is already available through this link:
    http://www.st.com/stonline/products/literature/um/13379.pdf
    Cheers.
    wuxiangdong
    When I make a DFU file from a Hex/S19/BIN file with DFU File Manager, I must input the infomation below:
    1.Target ID
    2.VID
    3.PID
    4.Version
    5.Target Name
    My question is what the five infomation means?
    This is my guess, is this right?
    1 > I think that Target ID desided the data will be whrite to where:
    00 : Internal Flash
    01 : SPI Flash
    02 : NOR Flash
    03~FF : ?
    2 > VID : Vendor ID ?
    May I set with any number I will? or just the ''0483'' is valid for ST?
    3 > PID : Product ID ?
    May I set with any number I will? or just the ''088D'' is valid for STM3210E-EVAL?
    4 > Version :
    May I set this as I will?
    5 > Target Name :
    Thanks.
    [ This message was edited by: wuxiangdong on 15-12-2009 11:38 ]
    wuxiangdong
    Cheers.
    Oh, Thanks for answer.
    I had read this document before I saw your answer.
    But this document just tell me what those are, and I do more care about wether I can write the VID/PID/Version as I will.
    For example, if I write 0x0000 for VID, do I meet some trouble?
    however,thank a lot.
    [ This message was edited by: wuxiangdong on 21-12-2009 03:12 ]
