MQi.1
Senior II
December 5, 2023
A question about F103C8T6 memory map.
I found in "Figure 11. Memory map" of "Datasheet - production data for STM32F103x8", the address span between Port A and Port B is 1024(0x4001 0c00 - 0x40010800 = 32*32 bits), while I found in "RM0041 - Reference manual STM32F100xx advanced Arm ® -based 32-bit MCUs", there are only 7 32-bit registers for Port A, and there are not preserved space there, so my question is what is the other 25 32-bit space, are they used for remapping "I/Os alternate function configuration"?
TDKBest answer
December 5, 2023
They're nothing. They either don't exist and/or aren't meant to be used by the user.
Keep in mind you're interacting with registers, not memory. There is no reason that the space needs to be contiguous.
TDKBest answer
December 5, 2023
